Hi all.
I'm new to this forum (and to Victron/ off-grid devices) and so far this community has been a great source of info.
First of all my setup:
- Cerbo GX
- Multiplus 2 48/5000/70-50
- SmartSolar MPPT 450/200tr
- Smartshunt 500A
- LiFePo4 280Ah
- JK BMS 200A
- Mk3 USB Interface
Using the MK3 Interface I can see the Multi is setup to start charging when either the Udc or SOC is below a certain setting.
When the Multi start charging it continues to do so until either Bulk or Absorption is finished.
Meaning I end up with a full battery (which I don't want). There is an option to stop the Multi from charging when Udc is higher than .....Volts.Which to me is not very useful because of the flat battery curve.
Is there an option to stop the Multi from charging at a certain SOC?
All input/help is appreciated.
Kind regards,
Bart
