troycamper avatar image
troycamper asked
MPPT not showing solar, battery readings inaccurate
Having problems with our set up, MPPT (100/20) showing 0-1w and battery reading is showing as 13.78, but multimeter showing 12.16.
The wires did get accidentally unplugged, but not working properly since plugged back in.
Sometimes the app doesn't come up with the controller at all.
MPPT Controllersmppt state
klim8skeptic avatar image
klim8skeptic answered ·
Have you checked the fuse in the bottom of the mppt?
Otherwise there should be a fuse between the battery and the mppt that should be checked.
