andy22 avatar image
andy22 asked
Powering Cerbo GX with external power supply possible? Externes 24V Netzteil erlaubt?
can I supply the Cerbo GX with a normal 24V power supply (AC/DC) if I have a BMS connected via VE.CAN (Batrium) at the same time (48V LFP battery)? Or is there anything against it?
Hallo,
kann ich den Cerbo GX mit einem normalen 24V Netzteil (AC/DC) versorgen, wenn ich gleichzeitig ein BMS über VE.CAN (Batrium) angeschlossen habe (von einer 48V LFP Batterie)? Oder spricht irgendetwas dagegen?
cerbo gx
awalkerinuk avatar image
awalkerinuk answered ·
I do just that. Not sure if there is anything against it though.
I just like the fact it is always on. Being grid tied it was just easier.
Jean-Pierre Krickx avatar image
Jean-Pierre Krickx answered ·
You can use any DC power supply between 10 and 70 volts to power the Cerbo.You can also connect de Cerbo directly to the batteries.
andy22 avatar image
andy22 answered ·
Thank you!
Jean-Pierre Krickx avatar image Jean-Pierre Krickx commented ·
You are welcome
