alzoo avatar image
alzoo asked
IP65 12/10 no amps while charging in bulk/absorption
Hi guys @Matthias Lange - DE
More or less new to this device, it works really well the last 9 charges on my aldi deep cycle 80Ah lead battery, however this time i'm getting no amps when trying to charge it. it stays a short period in bulk and goes to absorption before float quickly. (see history) A mutlimeter on the battery gives me no volts at all at 0.06V, I assume the battery is a beyond a charge?
I'm not certain if it's the charger that is not working.. even not connected to a battery it is in absorption mode with 14.4V and no amps. when I reset it to defaults, it goes back to to that phase. is that normal?
VictronConnect_report.zip
ChargeCycleHistory.zip
many thanks
Alzoo
batteryip65amps
kevgermany avatar image
kevgermany answered ·
Faulty battery can give this behaviour. Most likely the battery.
alzoo avatar image
alzoo answered ·
I'm guessing the best thing is to test on another type of lead battery?
alzoo avatar image
alzoo answered ·
hi, anyone able to answer my question please?
The battery is dead. And it is not taking a charge if the voltage shoots up when the charger connects to it.
You can test the charge by putting it into power supply mode and checking its output.
