I’ve searched… I read the Victron Connect manual… please tell me what this is and what settings affect it.
In the MPPT manual this is the description:
Use this function to create a virtual load output if the solar charger does not have a physical load output.
The TX port will switch using the same conditions as set in the load output settings.
Connect the VE.Direct TX digital output cable to a BatteryProtect module, a relay or directly to the remote on/off connector of the load.
74 People are following this question.
SmartSolar MPPT 150/85 VE.Can - No current flow in Bulk with PV at VOC
Are 50vdc solar panels wasted on a 12vdc system?
Large difference between solar blanket voltage output and Victron dashboard
Japanese RV Build— Stuck on Bulk / Configuration Review
Peak Power Pack 40Ah and SmartSolar charge controller - how to connect & setup
