etedverhard avatar image
etedverhard asked
Multiplus II GX AUX-port
I want to use the AUX of my MPII-GX for indicating the primary powerloss.
Unfortunately I can't find the right items to configure it.
Problem is: My house is fully connected to my 3 MPII, so we don't notice a powerloss of our supplier.
I want to indicate the happening with some LED's so I can adapt my energy consumption.
Also in case of emergency-power of the MP's, the wallbox for the vehicle should switch of.
Unfortunately I don't have the Victron Wallbox
Can you give me a hint, how to configure this?
Thank you
aux
Jason - UK avatar image
Jason - UK answered ·
@ETEDVERHARD Most people put non-critical loads on the AC-out2 of the Multiplus unit so in the event of a power cut, the AC-Out2 disconnects in the event of a grid failure. If you want to activate a led, you can set up an assistant to activate one of the relays in the event of a grid failure.
etedverhard answered ·
That was what I was searching for.
Thank you very much.
