matthias48 avatar image
matthias48 asked
MultiPlus-II wall mounting without mounting bracket
Hello!
Is it OK/safe to mount the MultiPlus-II 48/8000/110-100 on a bricket wall via the 4 holes in the corners without using the mounting bracket?
The upper left one is a bit harder to get to, after removing the front cover, but theoretically accessible.
Thanks a lot,
Matthias
Multiplus-IIinstallation
shaneyake avatar image
shaneyake answered ·
Yes, you can mount the inverter using just those 4 points.
We use them for when the inverter is mounted at strange angles or in our mobile systems.
matthias48 avatar image matthias48 commented ·
Thank you very much for your answer!
