Paul Simon avatar image
Paul Simon asked
MPPT current reduction at low temperature - hex protocol
Hi to all!
The documentation of the ve.direct hex protocol mentions a settings register with the name "Low temperature charge current". Its address is 0xEDE6 (in big endian notation - so bytes need to be reversed when sending a command). And there is another register with the name "Battery low temperature level" and address 0xEDE0.
Since these settings are a bit poorly documented I wanted to ask: If I set "Low temperature charge current" to 5A and "Battery low temperature level" to 5°C will the charger reduce its charging current to 5 Amps at Temperatures below 5°C - provided it receives battery temperature readings from a BMV or SmartShunt?
The two corresponding commands would then be :8E6ED00320048 to set the current limit and :8E0ED00F4018B to set the temperature, right?
Thanks!
MPPT Controllers
@Paul Simon
Moved to modifications. Better here
Paul Simon avatar image Paul Simon kevgermany ♦♦ commented ·
What? This is not a modification. This is just a rather poorly documented feature.
