wdh2550 avatar image
wdh2550 asked
How to operate the MultiPlus-II switch with Node-Red ?
The ESS Control node only provides "Disable Charge"
The "Multi Control" node cannot be configured, it just displays: There are no multi services available. Please check that a multi is connected or try a different node.
With the Remote Console the Victron Multiplus II switch can be operated and put in one of four states on/charger only/inverter only/off.
When SoC and PV power are low the Multiplus II is just consuming power without doing anything usefull. Therefore I would like to create a Node-RED flow that turns the MultiPlus II on or off depending on SoC an PV power.
Multiplus-II
wdh2550 answered ·
The "VE. System Control Bus" node provides access to the Victron Multiplus II switch states ( on/charger only/inverter only/off). Found it by browsing the node-red code ( /usr/lib/node_modules/@victronenergy/node-red-contrib-victron/src/services/services.json) on the CerboGX.
https://github.com/victronenergy/node-red-contrib-victron/wiki/Available-nodes is a lot easier to search through (and generated from the services.json file)
