pmgia avatar image
pmgia asked
Is it possible to Connect CerboGX via CAN to a BMPro RV Master?
I have a Class B, Mastervolt Inverter, Replaced a GoPower MPPT with Victron and BMPro RVMaster. Since removing the GoPower I lost all my solar data and would like to get it back for inverter and RVMaster. If so, what data can I expect to see? Thank you.
cerbo gx
gibsonae avatar image
gibsonae answered ·
Hey @pmgia
Ive got a BMPro odyssey 104 (seems to be a basic setup compared to yours)
My system uses a rj12 cable from the BatteryPlus35-II-SI to the control node then to a display
The control node looks after the bluetooth connection and water tank sensors.
From my quick testing the the rj12 plug pinout is
1 - White - 12v
2- Blue - 12v
3 - Red - Data+
4 - Green - Data-
5 - Yellow - Gnd
6 - Blue - Gnd
The BMPro app does say it uses the rv-c protocol but havent been able to get it to work.
Also may be a connection issues so im currently waiting on some RJ12 breadboard adaptors to help with testing
gibsonae answered ·
Just an update.
I've gotten the cerbo unit to relay the data
But I can't get the cerbo unit to read the data.
Going to chat with a bmpro software Engineer about this
