zw01 avatar image
zw01 asked
Solution for weak wifi signal EV Charging Station?
I have the following problem when setting up the Victron EV Charging Station:
When scanning for Wif-Fi networks, the EV Charger sees the Cerbo. When I want to connect to it, the message "An error occured during applying of new settings!" appears.
I think the problem is that the EV charger has a very weak wifi signal. At more than a meter away there is already almost no signal. If I stand behind the wall where the charger is hanging, there is already no signal at all.
It seems to me that the charger's wifi signal cannot possibly reach the Cerbo (about 4 meters away).
Is there a solution?
ev charging stationwifi
Chris Hill avatar image
Chris Hill answered ·
Have you thought about a wifi booster closer to the charger, you can also get Wi-Fi extenders which you plug in to the wall with a sender and receiver
Like these
TP-Link AV600 Powerline Adapter Wi-Fi Kit, Wi-Fi Booster/Hotspot/ Extender, Wi-Fi Speed up to 300Mbps, 2+1 Ethernet Ports, No Configuration Required, Wi-Fi Auto-Sync, UK Plug (TL-WPA4220 KIT)
https://amzn.eu/d/hbfy8e3
zw01 avatar image
zw01 answered ·
Hello Chris,
Thank you for your response.
Yes, I have tried that. But the charger refuses to connect to my Fritz! wi-fi extender.
zw01 avatar image
zw01 answered ·
Anyone from the Victron team here?
Things are really getting complicated now.
According to my supplier's technical service, the software my EV charger has a bug, which prevents it from connecting to my router. Therefore an update needs to be done first.
Updating via VRM portal is not an option in my opinion, because you have to disconnect the internet connection to contact the EV Charger.
There is another possibility: update over the internal web interface (available from v1.22). However, my EV Charger has v.1.19.
How can I update my EV Charger now?
s-forsberg avatar image s-forsberg commented ·
Did you solve it?
zw01 avatar image zw01 s-forsberg commented ·
Hello s-forsberg,
Apologies for the late reply. Yes, it has been resolved.
The EV Charging Station had a malfunction and has been repaired by Victron's service department.
The problem is now fixed.
