over-and-under-victron avatar image
over-and-under-victron asked
Exceeding the Cerbo's USB power?
I was wondering what happens if you exceed it's USB power ability?
I was wondering if it could power a small mini router?
https://www.amazon.com/GL-iNet-GL-AR300M16-Ext-Pre-Installed-Performance-Programmable/dp/B07794JRC5/ref=cm_cr_arp_d_product_top?ie=UTF8
cerbo gx
I've never tried to exceed the power limit of USB-A (1.1 and 2.0 = 500mA) port, but as far as I know it will terminate the connection as per standards.
over-and-under-victron avatar image over-and-under-victron commented ·
As long as it won't damage it's little power converter.
It would help clean up my wiring.
Would this be asking for trouble....
My Cerbo powers the Lynx fuse lights - could I use the Lynx pass through to power this router?
kevgermany avatar image kevgermany ♦♦ over-and-under-victron commented ·
I checked the listing, it doesn't give power consumption. But there's a recent question answered by the seller, saying it needs a 5V/2A supply, but draws less than 2W. The description asks for a 1A supply.
Might work, but you're probably on the limit. I'd suggest using a powered USB hub or direct power supply.
