dmc-solar avatar image
dmc-solar asked
Multiplus 3000 inverter turning off then back on repeatedly
I installed my multiplus 3000 over 2 years ago and has worked perfectly.
a few days ago the inverter switched to OFF on its own then restarted and back to ON.
it was only off for about 30 seconds to a minute.
We are connected to shore power on a 30 amp connection and i have the input set to 26amps
Last night it happened again at 4am, it turned OFF then ON again 6 times over a 40 minute period.
I downloaded the info from the VRM and it shows the VEBUS switching to OFF.
At the time of the shut down we had no excessive loads, only about 900 watts from the refigerator.
I turned the fridge to propane, which brought the load down to about 300 watts.
the inverter shut down again
We have a southwire surge guard 50amp surge protector built in, it had no alerts or alarms while on shore power.
Looking at the data, in shore power was consistently 122 v and 60 hz
I cut off the shore power to see what would happen on inverter/battery power alone.
the system worked perfectly and no shutdowns while on inverter alone.
Looking at the VRM data several of the chart have weird spikes and valleys
Please look at the vrm data below, I have no idea why this is happening
Our system
Inverter
Victron Multiplus 3000 12 Volt Inverter
Batteries
Battleborn Lithium 100ah 12 volt batteries x 4
50 Amp Connection to RV Panel
AM Solar - Smart Phase Selector to allow feed to both sides of 50 amp
Control
Victron Color Control GX Display
Solar Controller
Victron Smart Solar Charge Controller MPPT 150/100 - TR
Battery Monitor
BVM 712 Smart Battery Monitor
Solar Panels Watts VMP VOC IMP ISC
New Powa 200-24V 200 34 40.46 5.88 6.23
Panel Mounts
AM Solar Rocker Mounts
Combiner Box
AM Solar C-Box and Heyco liquid tight strail relief for 10/2 round cable
Solar Panel Cable
10 gauge duplex round cable with UV resistant jacket
Combiner Box to Charge controller cable
2 gauge duplex 2/2 cable
Battery Cable
4/0 Red and Black Welding Cable with 4/0 - 3/8th lugs
Fuse
400 Amp Fuse between battery and invetrter and 12v loads
VE configure settings
VRM screens last 6 hours
See all the activity from 3:42 to when i cut off the shore power at 4:09
1669027713926.pngThis spreadsheet from the VRM download shows the inverter going off 6 times from 3:45 to 4:05
The inverter has been running perfectly off of inverter/batttery since i shut off shore power
Please help with any reasons why this would happen
multiplus ve.bus
dmc-solar answered ·
Can anybody help me with this, i posted it a week ago and so far nobody was able to help explain this issuse.
thanks Larry
nickdb avatar image
nickdb answered ·
So what batteries are you using?
First off the charts show a discrepancy between the bmv voltage reading and the multi - the latter is much lower, charted down to 11V (graphs aren't granular so in reality it could be lower).
Your cutoff voltage is 10.5V.
Both DC charts show voltage decay so it looks like the battery voltage is dropping under whatever load there is.
You need to check your wiring and connections to see why the multi has a much higher voltage drop, if you get to the bottom of this it should stabilise.
I would attach a marked up image but this site seems to have issues with attachments at the moment.
