jonathanr avatar image
jonathanr asked
MPPT as a DC to DC converter
I have a large battery with a nominal voltage of slightly over 48v. On the solar side, I have 2x MPPT 100/20 and 1x MPPT 150/35, with 48v loads made up of a 48v Phoenix 1200w inverter and a 48v to 12v DC to DC converter buck converter (non-Victron). I have all of the Victron devices monitored via Venus OS
I'm hoping to use a spare SmartSolar MPPT75/15 as a replacement to the DC to DC buck converter, where I would connect the 48v battery to the PV input and use either the load output or battery output of the MPPT75/15 as a 12v power source to my 12vDC system. I have three questions.
  • First, is it better to use the battery output or load output of the MPPT75/15 as the DC output to my 12v system?
  • Second, is there anything I need to configure beyond setting the battery voltage on the MPPT75/15 to 12v in order for this to work and to have Venus OS understand this as a DC to DC converter, not a PV charger?
  • Third, generally, my 12v DC sources draw less than 15 amps; however, given that I already have the buck converter, I plan to wire it in parallel with the MPPT75/15, and have both the input and output connections of the buck converter switched so it will normally be disconnected but can be manually connected in the event of a higher current need. Does anyone see any issues with this setup?
MPPT ControllersVenus OSdc system
nickdb avatar image
nickdb answered ·
Just use the search function on the site, plenty of others having the same idea and then learning the wonders of physics.
jonathanr avatar image jonathanr commented ·
Thanks, I have done some searching.
I found a bunch of threads looking to use an MPPT as a step-down battery charger. The primary risk described was related to the PV connections being shorted on some error conditions, which I planned to manage by fusing the PV (48v battery) input.
I also found some threads about using a DC charger as a PV input to an MPPT to charge a battery, with the primary risks being around overloading the DC charger.
In both of the above use cases, there is a 12v battery involved which is being charged; however, in my use case, there would be no other voltage source on the 12v side.
Some hints as to which physics you are referring to would allow me to consider that issue.
MPPT Product Page
MPPT Error codes
Victron Venus OS Open Source intro page
Venus OS GitHub (please do not post to this)
