I need to make the system charge the battery and our installation run from the batteries. How do I turn off passthrough
I assume you have a MultiPlus or Quattro?
You can't make the converter be both a charger and an inverter at the same time, it can only be one or the other. So if you want to charge the battery and have AC available on the output, then passthrough is the only option.
We have 2 Quattros
I've also just noticed the mode change from passthrough to bulk with no user input.53 People are following this question.
