tony-torres avatar image
tony-torres asked
Programmable Relay, ON/OFF triggered same time, which one is higher priority?
If I have two programmable relays assistants to set the K1 ON and OFF, and at some point, both assistants set the K1 ON and OFF. How will be the status of K1? ON or OFF?
Let´s say the logics are the following:
- Assistant1: K1 set ON if SOC Higher than 20%
- Assistant2: K2 set OFF if SOC Higher than 80%
Result:
- SOC 50%= K1 ON
- SOC 81%= K1 ???
Assistants
JohnC avatar image
JohnC answered ·
@Tony Torres
The last one gets priority, so your "???" = OFF.
