Is the "MK3-USB" interface electrically isolated from the inverter
Yes, it is isolated.
My one uses an Analog Devices ADUM1201 for isolation and you can see good PCB isolation too.
The Victron Communications White Paper mentions the Mk2 and Mk3 are galvonically isolated.
Equivalent to electrically isolated?
Better off using VE Config with the dummmy port and uploading the config file from Dashboard > devices screen.
34 People are following this question.
