bpl avatar image
bpl asked
Phoenix 250VA inverter VE Direct PIN will not change
8dc33a2f-2a3c-44f5-9a24-e5d497af9730.pngHi, i connected to my new inverter Bluetooth via victron app. I changed the PIN. Every time i reconnect it prompts me with the default PIN warning. I have an MPPT which works ok from new no issues with that.
I forgot all VE Bluetooth connections
I restarted ios 16.1.1 phone
I restarted inverter power off disconnect
Then went round in circles doing the same thing over and over.
Please can someone help with this issue as i don't want anyone to connect to my inverter for safety reasons.
Peter
VE.Direct Bluetooth Smart Dongle
Hi @BPL,
When you forgot the bluetooth connection and reconnected, what PIN code did you have to fill in for a successful connection? Was that again the default one or the one that you changed it to?
Kind regards,
Thiemo van Engelen
I would try to say "not now" and than go to the settings -> the three dots in the upper rigt corner -> product info -> there you can also change the PIN
