franschhoek-electric avatar image
franschhoek-electric asked
Battery Monitor [512] Automatic monitoring High voltage alarm: Alarm
Having an issue on two sites where the BMS of the battery is connected, and settings are done according to the application note. I have limited the charge current to 50A and the charge voltage to 55VDC.
MultiPlus-II 5KVA firmware 498 and Cerbo GX firmware V2.92
Has any one had this issue and what's the best way to correct.
Kind regards
Chad
Multiplus-IIalarmfreedom won
nickdb avatar image
nickdb answered ·
What batteries are these?
New lithium batteries and high voltage alarms are common and generally need to be kept on keep charged mode for a few days, or have the CVL limited with DVCC while they balance.
Just noticed the tag that its FW. If it’s the e-tower its all normal.
