neilwhittal avatar image
neilwhittal asked
SOC on CCGX no longer appears
Hi - New guy here. I have installed a Multipus 48/5000 with a Smartsolar MPPT 250/100. This is a DIY install so far. When I first connected the CCGX, battery SOC always showed 100% which I did not understand as it never decreased. Now, the SOC does not show at all. Can someone help?
SOC
Paul B avatar image
Paul B answered ·
The multi plus always has the battery monitor turned off by default, you will need this to be setup using a victron MK3 usb to ve bus adapter
Once this is setup then the SOC will show.
you can get your victron agent to set this up remotely via the VRM as well as well
