peterepeat avatar image
peterepeat asked
VE.Bus Error 11 Communication Error
a 3-phase ESS with three MultiPlus II 48/3000 (Firmware 497) and a Cerbo GX (Firmware 2.91) working for a month without a problem - now getting a VE.Bus Error 11 - 0x800016 - BF safety test OK - Communication error.
I already double-checked my Wiring and all the error 11 steps from https://www.victronenergy.com/live/ve.bus:ve.bus_error_codes. Could anybody give me a hint on this?vebuserror112022-11-10-084012.jpgCheers, Peter
error 11
peterepeat answered ·
Yesterday I got the same communication error again.
vebuserror112022-12-23-060203.jpgWhat type of communication may cause this problems? Communication between the MultiPlus II inverters or communication between CerboGX and the inverters?
Eduard Visser avatar image
Eduard Visser answered ·
Last night I had the same notification. Nothing seems to be wrong, but strange. At the same time a water pump took a small amount of current (0.7 Amp). Could it be a critical induction which has affected the VE bus communication cable, which is close?
You really want to try keep the vebus cabling away from power sources. The quality of cabling also can vary.
Eduard Visser avatar image Eduard Visser nickdb ♦♦ commented ·
Thanks, if I find some time I will separate them more.
