Hi everyone,
Wondering if someone could help me setup the app and the GX for the Australian propane tanks?
App has only 6 or 9 kg but we use 8.5.
Thank you
Hi everyone,
Thank you
I can not remember the exact menus, but the principle I used for non standard cylinders is as follows. Attach the sensor to a full cylinder, set the cylinder type to something larger than you have, it will report a content less than 100%. Swap the reading to depth which will give you the depth of liquid in a full cylinder. Then go to the cylinder type and select "arbitrary" or whatever the option is called then when setting this option up it asks for the full depth which you have recorded.
Victron temperature sensor disambiguation table - which product supports which sensor
33 People are following this question.
