paul-cotton avatar image
paul-cotton asked
Inverter control - Multiplus 12/1200
I have my inverter under the floor in my van. It is a pain to switch on and off and consumes my 100mAh battery too much on cold days. How can I control it so that it will not consume electricity? I am not sure what else it has connected, it does have a device on ethernet, but it does not look quite the same as the smart dongle i googled because it has no significant green plug on one end.
control
If AES is enabled, it will go onto a low power mode automatically. But you would need to check its programming with an mk3.
A picture of the item you are trying to identify would help us help you to do so.
