obenschlaefer avatar image
obenschlaefer asked
How to enable the project function ? - VenusOS Large - Node Red
iam using the venus OS Large image (raspberry4 v.2.92) and i want to enable the "project-function" as described here: https://nodered.org/docs/user-guide/projects/
But i cant find the correct "setting.js"
I set "project enbale: true" here:
  1. ./usr/lib/node_modules/node-red/settings.js
  1. ./usr/lib/node_modules/node-red/venus-settings.js
but nothing happens. Is it possible at all in the large image?
Thanks
Stephan
Node-RED
johan-b avatar image
johan-b answered ·
The NodeRed document says the projects feature will only work if git is available on the system, which isn't available on my Cerbo GX device.
I use the NodeRed project feature on my HomeAssistant install (which has git installed) and I agree it would be a nice feature to have to as it allows for revisions and backups of the Victron NodeRed flows.
It is not too hard to install git. Just login via ssh and:
  1. /opt/victronenergy/swupdate-scripts/remount-rw.sh
  2. opkg update
  3. opkg install git
usernamepasswordbs avatar image usernamepasswordbs Dirk-Jan Faber (Victron Energy) ♦♦ commented ·
Thank-you.
