no13coffee avatar image
no13coffee asked
Generator advice needed please
Hi All,
I have this Easy solar setup in my coffee truck (horsebox) i have 560ah of battery storage, in summer when we're doing events we have never come close to running out of power 300ah solar panel on roof. but we're about to start with winter/xmas events, we came close a couple of times recently to dipping below 50%, so what id like to know is what power generator would i need to help keep the batteries topped up or give them a boost,
List of kit we're running
Double door fridge (not working as hard though in winter)
Coffee grinder
led lights
water pump
Our coffee machine is LPG, but i can switch it on 240v 1kw if we start to get busy and its temperature starts dropping
Thanks,
Cheers Tim
EasySolar All-in-One
David Gould avatar image
David Gould answered ·
you can set the input current limit to 4amp via dip switch and just use a 2kw suitcase generator so you not maxing it out
no13coffee avatar image no13coffee commented ·
Thanks for your quick reply
