The battery temperature sensor is off by about 8 degrees, reading low. Swapping temperature sensors gets the same result, problem is in the internal circuit reading the temperature sensor. Is there a way to calibrate this?
I have the same problem ! What is the official solution ?
Thanks !
Victron temperature sensor disambiguation table - which product supports which sensor
35 People are following this question.
