ks4z avatar image
ks4z asked
SMartShunt: Value for TimeToGo when charging on DBUS
Hi all,
as I wrote in another post, I am working on implementing a SmartShunt alternative based on a PZEM-017.
I am struggeling with the Time to go. I know that the Remote Console shows Infinite (or --) when the battery is charging. The documentation says that 864000 is the max value when not discharging. My assumtion was that this value (or a higher one) triggers the --, but it does not.
Does anybody know how I can achieve the correct display? Maybe someone with a SmartShunt can check the DBUS value for TimeToGo while charging and let me know?
Thanks
ks4z
cerbo gxSmartShuntbattery
Kevin Windrem avatar image
Kevin Windrem answered ·
'--' usually means the parameter is not currently defined. You can remove the parameter from dbus to generate the '--'
ks4z avatar image ks4z commented ·
Thanks a lot. That's it. Just setting it to None doe the trick.
