SmartSolar 150/85 production year 2016.
Are Q100, Q102 and Q109 same type of Mosfets - IRFI4321 as others?
What else can be burned? Any Schema of this part?
No Idea, the only way to know is to open a similar unit and check, or just give it a go -
As far as I know systems electronic diagrams are NOT released
If those transistors are all in parallel then they would most likely all be the same.
Check the gate resistors and work back towards the gate driver to check that too.
As said before, no schematics are publicly available, so you'll need to work it out from the PCB yourself.
@Mindaugas
you asked: Are Q100, Q102 and Q109 same type of Mosfets - IRFI4321 as others?
Yes they are all the same ;-)
72 People are following this question.
