Hi everybody
What is the streetlight function. Is it possible to produce current with it ? I confess I've not understood this function. Thanks.
Hi everybody
Hi Nexo, see here: https://www.victronenergy.com/live/victronconnect:mppt-solarchargers#streetlight_settings
Its a switched output (on/off); combined with a pwm signal. That signal is designed to be compatible with various LED drivers; as a control signal to control LED intensity.
Its not a current source, and not a LED driver. Instead, its intended to be connected to one.
Ps. More info here: https://www.victronenergy.com/cables/ve-direct-tx-digital-output-cable
7 People are following this question.
