crossflow avatar image
crossflow asked
Inverter Phoenix VE.Direct 1200VA ECO mode
HI,
I bought a Phoenix VE.Direct 1200VA inverter because of its low power consumption in ECO mode.
The manuals reports that "The default ECO mode wake-up minimum power is 15 Watt"
I tried connecting a 50W incandescent lamp and it doesn't turn on.
Is it possible that the inverter has defect or for some reason had been factory programmed with a higher load detect level?
Thank you
Phoenix InverterVE.Direct
I know of 3 different model Phoenix 1200w inverters.
Got a link to your model??
crossflow avatar image crossflow klim8skeptic ♦ commented ·
It's the 24V version
here is the link to the datasheet, as said, it's the 24/1200 version
https://www.victronenergy.com/upload/documents/Datasheet-Phoenix-Inverter-VE.Direct-250VA-1200VA-EN.pdf
this is the manual of the inverter https://www.victronenergy.com/upload/documents/Manual-Phoenix-Inverter-VE.Direct-250VA-1200VA-EN-NL-FR-DE-ES-IT.pdf
Eco mode is explained at page 7
klim8skeptic answered ·
With Victron Connect you can change some of the ECO mode working parameters. Download Victron Connect and check what is configurable via DEMO mode.
Unfortunately you need a VE direct bluetooth dongle, or an usb>VE direct cable. Not all loads work well with ECO mode.
Make sure that the jumper is in the REMOTE port.
