enodev avatar image
enodev asked
Forum emails ending in SPAM folder recently...
Hi Victron guys, (CC: @mvader (Victron Energy))
Something happened recently, and most of the email sent from the forum are ending in SPAM. Looks like there are some outgoing email settings missing for victronenergy.com emails. DMARC (DKIM + SPF) ???
Here are the headers from the message I get...
X-Spam-Score: 6.3
X-Me-Vssu: VW5zdWI9aHR0cHM6Ly9jb21tdW5pdHkudmljdHJvbmVuZXJneS5jb20vdXNlcnMvMTg0ND MvZW5vZGV2L3ByZWZlcmVuY2VzLmh0bWwjL25vdGlmeVRhYg
Authentication-Results: mx1.messagingengine.com; x-csa=none; x-me-sender=none; x-ptr=pass smtp.helo=mail186-7.suw21.mandrillapp.com policy.ptr=mail186-7.suw21.mandrillapp.com
Authentication-Results: mx1.messagingengine.com; bimi=none (No BIMI records found)
Authentication-Results: mx1.messagingengine.com; arc=none (no signatures found)
Authentication-Results: mx1.messagingengine.com; dkim=pass (1024-bit rsa key sha256) header.d=mandrillapp.com header.i=@mandrillapp.com header.b=CI5ULBvL header.a=rsa-sha256 header.s=mandrill x-bits=1024; dkim=pass (1024-bit rsa key sha256) header.d=victronenergy.com header.i=bounces@victronenergy.com header.b=hIavlxa3 header.a=rsa-sha256 header.s=mandrill x-bits=1024; dmarc=pass policy.published-domain-policy=reject policy.applied-disposition=none policy.evaluated-disposition=none (p=reject,d=none,d.eval=none) policy.policy-from=p header.from=victronenergy.com; iprev=pass smtp.remote-ip=198.2.186.7 (mail186-7.suw21.mandrillapp.com); spf=pass smtp.mailfrom= bounce-md_30161135.634fe8a3.v1-4a8a340e013f44d881d6902c1f14dce1@mandrillapp.com smtp.helo=mail186-7.suw21.mandrillapp.com
X-Sieve: CMU Sieve 3.0
X-Me-Vsscore: 530
X-Spam-Sender-Reputation: 500 (none)
Return-Path: <bounce-md_30161135.634fe8a3.v1-4a8a340e013f44d881d6902c1f14dce1@mandrillapp.com>
X-Me-Vscategory: spam:high
X-Me-Csa: none
X-Spam-Hits: HEADER_FROM_DIFFERENT_DOMAINS 0.25, HTML_FONT_LOW_CONTRAST 0.001, HTML_MESSAGE 0.001, ME_HAS_VSSU 0.001, ME_SC_NH -0.001, ME_SENDERREP_NEUTRAL 0.001, ME_VADESPAM_HIGH_NB 5, RCVD_IN_DNSWL_NONE -0.0001, SPF_HELO_PASS -0.001, SPF_PASS -0.001, URIBL_GREY 1.084, LANGUAGES en, BAYES_USED none, SA_VERSION 3.4.6
Arc-Seal: i=1; a=rsa-sha256; cv=none; d=messagingengine.com; s=fm3; t= 1666181284; b=r9p9E62mY9y3ALbBJEUpfZXojFilGrhyK/Y98Yb229wXaQ3KxG 4vADn9+FmH9FA818zjXBkQRLzfH7xyGCIhRK/e2XFDID/qm9YtF2IAKp9ZJFqMY/ G6gOiEwCmITCLb8stpg3k0svUBHC68floKiRLibsqiO9TCPlgnuCyCjD+0hwm91a sLJGr1PwcG3DaVz9ZzMXz1l+P2mllPNZInZmCmrBOnrBkEONsHUi5uPqbcQm/QMx 6kB00AorQ6wnVdWWMjcaCCrokQqBGU4q2ADXsblfZqPzpjSjzYjQsDiXyCTYk3za qx2QJpsvjCZgDVli2DsI7Dr7d36mDcMQo8sA==
X-Mail-From: bounce-md_30161135.634fe8a3.v1-4a8a340e013f44d881d6902c1f14dce1@mandrillapp.com
X-Spam-Known-Sender: no
X-Report-Abuse: Please forward a copy of this message, including all headers, to abuse@mandrill.com
X-Report-Abuse: You can also report abuse here: http://mandrillapp.com/contact/abuse?id=30161135.4a8a340e013f44d881d6902c1f14dce1
<bcc1f28b-a705-4dde-8176-77b0c71746e7.9a2013fc-915d-4d27-9c48-0de889417241.1267554.18443.ANSWER.724848e1a83c7162fae8a25afa27dd1@victronenergy.com>
Arc-Authentication-Results: i=1; mx1.messagingengine.com; x-csa=none; x-me-sender=none; x-ptr=pass smtp.helo=mail186-7.suw21.mandrillapp.com policy.ptr=mail186-7.suw21.mandrillapp.com; bimi=none (No BIMI records found); arc=none (no signatures found); dkim=pass (1024-bit rsa key sha256) header.d=mandrillapp.com header.i=@mandrillapp.com header.b=CI5ULBvL header.a=rsa-sha256 header.s=mandrill x-bits=1024; dkim=pass (1024-bit rsa key sha256) header.d=victronenergy.com header.i=bounces@victronenergy.com header.b=hIavlxa3 header.a=rsa-sha256 header.s=mandrill x-bits=1024; dmarc=pass policy.published-domain-policy=reject policy.applied-disposition=none policy.evaluated-disposition=none (p=reject,d=none,d.eval=none) policy.policy-from=p header.from=victronenergy.com; iprev=pass smtp.remote-ip=198.2.186.7 (mail186-7.suw21.mandrillapp.com); spf=pass smtp.mailfrom= bounce-md_30161135.634fe8a3.v1-4a8a340e013f44d881d6902c1f14dce1@mandrillapp.com smtp.helo=mail186-7.suw21.mandrillapp.com
forum
enodev avatar image
enodev answered ·
Not sure who fixed what and where, but recently everything is back to normal.
