maddin avatar image
maddin asked
Temp. Sensors (RUUVI) not show on cerbo GX after update
The temperature sensors (ruuvi) does not longer show on the cerbo GX ( Remote Console, diagram). All setting same, as before the update to 2.92. In VRM all temp. sensor are showing, so the setting, bt , and else are working !
Someone of the users or Victron have an explanation of that ?
Temperature Sensor
Paul B avatar image
Paul B answered ·
Check to see if there is a bluetooth menu under setting on the cerbo GX
if not then my suggestion is to go and buy a USB bluetooth dongle and plug it into the usb port, then the bluetooth will apear again.
Some of the cerbos had a bluetooth issue when there internal temp got high.
anyway if the bluetooth option is missing you have two choices take it back for a warranty claim or buy a bluetooth dongle. it maybe easyer just to buy the bluetooth unit a tp-link HB400 works fine
Victron temperature sensor disambiguation table - which product supports which sensor
