Jürgen Scharfe avatar image
Jürgen Scharfe asked
MPPT Bluesolar 150/85 no charge current incorrect display
Good afternoon
My Bluesolar MPPT 150/85 ceased correct operation after a small short on the pv side (unfortunately between PV panel fuses and MPPT )
First it showed a warning "inf 21 " then after complete discconnecting no more error messages but now
- current reading is 0 A , but PV current seems to be simply passed through
- measured current from PV is 7 amps ( cloudy ) and output current is exactly identical
- Voltage on panel is battery voltage + approx 0,7 V
- No MPPT function -
Is there anthing likee a fuse or so ?
Anything I can do ?
battery chargingfuses
boekel avatar image
boekel answered ·
Contact your distributor / dealer for repair / replacement.
Jürgen Scharfe answered ·
Thank you for that swift response - sounds like a more expensive repair.
However I find the issue quite strange - the short occured on the PV side , not one of the fuses blown. It looks like an issue with the current sensor .
But can the sensor be blown if the short occurs on the primary - something very strange
I expected something like:
"no problem you can replace part xyz or PCB No. Z and then it should work"
My dealer is no more avauilable ,
If it were only a fuse or so I would fix it myself
Best regards
Jürgen
gdam avatar image
gdam answered ·
Juergen - did you get any further with this? I have the same problem. Error 21 - current sensor fault. What causes this in the first place and is there a fix/repair if disconnecting and reconnecting PV and battery doesn't help?
