garryhydro avatar image
garryhydro asked
mppt 75/10 stops charging
I have 100 watt panel connected to a mppt 75/10 charging a 100ah gelcell 12 v battery. It charges and maintains the battery for about 3 weeks then the battery starts to drop voltage. When I visit the site the mppt lights are flashing between modes and I have to disconnect everything and reconnect to get it charging again. Why is this happening
battery charging
Paul B avatar image
Paul B answered ·
check your PV voltage when you get the issue and is it above startup voltage etc etc.
can we see some displays when the problem occurs
Guessing have a look at this post, this maybe the cause.
My mppt 100/50 will not turn on when pv starts to produce
