I want to update from firmware version 158 to 400plus, how do i go about it.
The instructions for updating VE.Bus firmware are here:
Old method using VE.Flash. You'll need to use this method because your current firmware is 158. https://www.victronenergy.com/live/updating_firmware:updating_ve.bus_products
New method using VictronConnect. This method is only available with 4xx firmware. https://www.victronenergy.com/media/pg/VictronConnect_Manual/en/firmware-updates.html
Remotely Update VE.Direct Firmware
VictronConnect manual / Firmware updates
Updating a Victron Smart Solar MPPT Charge Controller with Victron Connect
VictronConnect configuration guide for VE.Bus products - Firmware Updates
34 People are following this question.
