thedeltaskipper avatar image
thedeltaskipper asked
Skylla-IP44 12/60 input power - 240VAC Split Phase?
I'm using a Skylla-IP44 12/60 to assist my MultiPlus-II 2x120 in charging but only want the Skylla to charge when the generator is running. My generator produces 240VAC split phase, my shore power is 120VAC only. If I power the Skylla off of L1 and L2 of the AC Out 2 on the Multi-Plus II it would only see power when the generator is running and not when I am plugged into shore power. Can the Skylla-IP44 12/60 accept two split phase hots instead of the hot and neutral as indicated in the diagram in the manual?
Multiplus-IISkyllasplit phase
