I'm learning Victron environment as newbie and I discovered the Scheduled Charging "feature" available from ESS menu.
After reading the different subject about this "feature" and experiencing myself on my installation I have come to the conclusion that, in its current state, this function is totally useless.
Point is that the ESS is forced in "keep battery charged" whatever the SOC condition state is (fulfilled or not)
Based on my programming experience of PLC system in the industry, the so called "feature" or "system feature" would be named bug by users. But changing slightly the managing logic for this feature could make it totally useful instead of useless.
Like changing the code from
if "scheduled time activated" then switch to "keep battery charged" if SOC < setpoint Start Charge battery else Stop Charge battery end if else Stop Charge battery Switch to selected mode in ESS end if
to
if "scheduled time activated" then if SOC < setpoint * 0.98 switch to "keep battery charged" Start Charge battery else if SOC > setpoint * 1.02 then Stop Charge battery Switch to selected mode in ESS end if end if else Stop Charge battery Switch to selected mode in ESS end if
What do you think?
