scottbl avatar image
scottbl asked
AC Input not showing correctly
On my Mutliplus II 48/8000/110-100 my AC in does not show correctly.
Above - Battery charging at 5368w AC In showing 0.8amps / -5w
img-3815.pngAbove - Normal operation Inverting from battery.
In systen Setup I have AC Input 1 as GRID?
Any suggestions how to correct this? The Multiplus II has acted this way from the start.
I am trying to implement ESS scheduled charging and feel this AC Input issues is stopping scheduled charging from activating.
ac
@ScottBl
Viewing through the VRM sometimes has that effect.
What does the local remote console do? Is it the same?
scottbl answered ·
Hi Alexandra,
Thank you for your message.
I am connected via the MK3 dongle and Local Multiplus II. I does show the same thing.
Image 1 below I am inverting and have the kettle on
Image 2 I am ON and has the kettle on.
I am happy to look at any other settings
Drew Strobel avatar image
Drew Strobel answered ·
I am having the same issue. Did you find a resolution?
Mine was working at first, and then about 30 minutes later shows 0watts no matter what I try.
