potgieter avatar image
potgieter asked
External control - no absortion or bulk
My device since 14 Sept, doesn't show absorption or bulk anymore, just external control. The voltage never goes to 55,8v as recommend for FREEDOMWON 15/12kw battery for absorption or float. Can someone please assist.
CCGX Color Control
nickdb avatar image
nickdb answered ·
A multi should be in external control, that is the correct state for an ESS system.
There isn't enough info here to troubleshoot it.
https://www.victronenergy.com/live/battery_compatibility:freedomwon
Follow this link, and step through every item and make sure your system is properly configured as documented.
Send your DVCC settings, pull the BMS limits CCL, CVL, DCL chart in VRM, and also cell min/max.
You need to understand if the voltage limit is being enforced by the battery for some reason, imbalance etc.
