tubamanandy avatar image
tubamanandy asked
Automatic Cut-off Voltages - 12/1200 Phoenix Inverter
I have 2 x 12v 100ah wet lead acid batteries in parallel. The automatic cut-off voltages around 11.2-11.5 approx seem a little on the low side? I appreciate when the load is taken off they will bounce back higher but can I run with the standard settings or do I need to increase them a little ? Thanks
low battery warning
