kiab115 avatar image
kiab115 asked
AC assist to battery bank?
I've just installed a Multiplus 24v/3000w/70a on a 24v/2700wh battery bank. Everything I read seems to indicate AC assist or power assist is designed to supplement AC, or shoreline, from battery bank. I'm setup in a house with my solar and I'd like to reverse that, to have AC only assist the batteries, when over 1000w or the battery is below a certain SOC. However in current tests the AC takes over completely when wattage goes over 1000w. Ideally I'd like the AC to "assist" the battery with only a certain amount of amps to assist the battery until a certian SOC level is reached. i.e. I'd like the batteries to be my primary source, bringing in AC only when needed, is this possible?
powerassist
Mike Dorsett avatar image
Mike Dorsett answered ·
no, but with a 3kW inverter, you should perhaps consider a larger battery. Setting the inverter threshold to say 2.7kW before switching to ac might also help.
