Does BBC anyone have experience with a VCerboGX an the VE.Can to NMEA 2000 interface and the cababilites to display different data and perimeters on a B&G Vulcan chartplotter?
I have a 12kw electric motor in my sailboat that is powered by a Sevcon Gen4 Size 6 controller. I would like to display Motor RPM, Current, Motor Temp, and Contoller Temp on my Vulcan 9 chartplotter.
The Sevcon controller has a CANbus High and CANbus Low signal in on the wiring harness. Can I connect that to the my CerboGX using VE.Can, and then connect the CerboGX to my NMEA 2000 backbone using the VE.Can to NMEA 2000 cable to display the Sevcon data on my Vulcan?
According to the CerboGX manual for the WS500 wiring, pin 7 and 8 are for CAN-H and CAN-L. I would just need to make a cable for this from my Sevcon controller.
Thoughts?
