Eduard Christiaan Marias avatar image
Cant conect to quatttro inverter through mk3 switch
All cables and mk3 switch have been replaced and proper pc programs are being used but still cant conect
MK3
Please read through and follow the troubleshooting instructions in this VEConfigure manual.
https://docs.victronenergy.com/veconfigure.html#troubleshooting
Please report back with the results of those tests if it still is not working.
Share
Paul B avatar image
how long is the cable that you are using from the inverter to the MK3,
try a shorter cable ie under 5 mtrs
1 comment Share
I am having the same issue with my new laptop. I have tried different MK3s, different cables and still not picking up a com port. When I try on my old laptop works fine. Is there nothing else I can do? And I also uninstalled and reinstalled all software with the USB drivers on VE Config.
