Why are there 3 FW files for the EVCS available on Victron Professional Dropbox?
What is the difference?
How to chose the correct one for an update via the webinterface?
Hi, we are preparing a new EVCS version and that's the reason.
To choose the right one, you can check in VRM/device list and click on your device. It should be c025, like in the picture below.
Thank you.
Can you select a wrong file and brick the EVCS or do you get an error message?
(Offline-Update via the web interface)
And if this is happening, it's our fault, not yours :)
So no worries!
hi , can some one share evs firmware file 1.27 ( product id C025 )
via vrm it fails to update ;(
It can be downloaded from here - https://professional.victronenergy.com/downloads/firmware/
35 People are following this question.
