Hi all,
On an MP ii DVCC with lead batteries, what is the purpose of "Limit managed battery charge voltage" please?
Hi all,
That is a setting designed for helping balance new bms-controlled lithium batteries, predominantly for pylontech.
You generally lower the limit to avoid alarms and keep the cells in a healthy range. It is not intended for normal use.
61 People are following this question.
