eliott avatar image
eliott asked
12v Smart BatteryProtect to drive from the LD signal from 48v VE.Bus BMS
Hi!
I have a 12v circuit that I need to shut down when the 48v LFP batteries send a low voltage singal. Is is possible to use the 48v LD from the BMS as an input for a 12v BatteryProtect?
48v connected to +H <- LD BMS, -GND <- Battery, while the in/out is a completely different 12v circuit.
thanks
Battery Protect
wkirby avatar image
wkirby answered ·
I would not like to connect these two directly. The signals are referenced to the battery on each device.
In your case, with separate systems, use a relay or opto-isolator between the two devices.
eliott avatar image
eliott answered ·
Ok, thanks, but the same question goes for a Cyrix-Li-load. Can that be driven by 48v and switch 12v?
