moodlyd avatar image
moodlyd asked
BlueNova LiFePo4 Batteries with non VE direct MPPT and no ESS on Multiplus
GOOD DAY, I have a Multiplus 3000/24/70-50; Serial Number : 11200700318.and a bluesolar MPPT 150/70.
I intend installing the Blue Nova LiFePo4 Batteries.
The questions I have:
1.The ESS assistant is not available on this ver of multiplus. So I currently use flags\general flags on the current setup.
What would the settings be for the LiFeP04 batteries?
2.the MPPT does not have a VE direct port and connects via VE Can. I do have a colour controller.
Will this setup work on the Blue Nova, that is connecting the MPPT to the CCGX via Canbus?
Please assist
MPPT ControllersMultiPlus Quattro Inverter ChargerLithium Battery
nigelfxs avatar image nigelfxs commented ยท
I recommend contacting BlueNova directly - they are very helpful. Ph. +2721 205 2000
0 Likes 0 ยท
moodlyd avatar image moodlyd nigelfxs commented ยท
Hi, Thanks, i sent the, an email as well
0 Likes 0 ยท
Murray van Graan avatar image
Murray van Graan answered ยท
The settings for Bluenova are:
Absorption 56.2v
Float 55.5v
Low voltage cut out 49v
Inverter restart 53v
Low voltage alarm 50v
As for the two running on the same CANBus I donโ€™t know, both the CanBus charger and bluenova run at 250kbps, so at least you donโ€™t have conflicting CanBus speeds. Best would be to try it, I have some of both in stock and can run a test and see? Alternatively, swop out the CanBus MPPT for one with Ve.direct.
moodlyd avatar image moodlyd commented ยท
Hi Murraunated, thanks for the prompt response.
I don't have the batteries yet to test, would be great if you can do a test?
Also, regarding using the older Multiplus that cannot run the ESS assistant, would there be any issues from using flags, would you know?
0 Likes 0 ยท
