aarno77 avatar image
aarno77 asked
Easyplus 12/1600/70 with generator use ac out 0 (bypass) off when vacuum cleaner (2400w) switched on
I have newly installed easyplus and connected a generator 5kva honda+sincro into ac in. 460 Ah flooded batteries. When charge mode on and using ac out0 to use heavy duty equipment like vacuum cleaner 2400w the dc charge and ac out cuts off immediately when switching vacuum cleaner on. 700w coffee maker works fine. What could be the problem. It should bypass 16A? After some tens of seconds the charge and ac out0 is back.
GeneratorEasyPlus
klim8skeptic avatar image
klim8skeptic answered ·
It sounds like the sudden load of the vacuum is altering the generators voltage/frequency to the point. that the multi opens its feed relay (and the relay K, output 0).
Have a read of the MultiPlus generator FAQ's.
MultiPlus Generator FAQ
GX - Generator auto start/stop
Automatic Generator start/stop
 Hybrid Generators
Virtual switch - Generator start/stop
