I have 4600 Wp of solar panels (divided in two strings). Can this be connected to a multi RS solar? If not, what is the best setup to accomplish this, knowing that I also want to connect a battery?
You haven’t stated what the panel specs are.
Output is rated at max 4000W. 4600W panels will rarely produce what they are rated at depending on installation and environment.
The tracker has a max panel voltage of 450V so make sure to configure the strings suitably and remember it has a 120V startup threshold.
Assuming all these numbers add up (perhaps use the mppt sizing calculator on the site) the RS could be a decent fit.
It has a single tracker, you can add more externally if required.
Abend, genau die Parameter der Solarmodule fehlen uns, sonst können wir nichts berechnen.
Selbst nutze ich 11x 400W GG bifaciale Module am Multi Rs Solar, funktioniert einwandfrei.
MfG Schroeder Daniel
30 People are following this question.
