member040 avatar image
member040 asked
Electrodacus SBMS0 and Cerbo GX / Venus OS possible? MQTT?
Hi all!
Did anyone came up with a solution for connecting the Electrodacus SBMS0 to Venus OS?
I wonder if its possible to convert the MQTT Messages by the SBMS to CAN.BMS, DBUS or Modbus using NodeRed and an ESP32. Or even all internal of Venus OS?
Can we make Venus OS accept a battery reporting status over MQTT? Or is this a bad idea over all?
Setup:
-Multiplus
-MPPT VE.CAN
-Cerbo GX
-Pi4 running Home Assistant
-Electrodacus SBMS0
-USB -> Ve.Bus MK3
Venus OSBMSModbus TCP
Louis van der Walt avatar image
Louis van der Walt answered ·
I'm busy adding it to the serialbattery driver.
You can follow the ticket for notifications if you want
Charles Gomes avatar image
Charles Gomes answered ·
@Member040 did you ever get your SBMS integrated with the Cerbo GX ?
member040 answered ·
@Charles Gomes Sadly not :/
Wondering if is there a way to help, or a path already laid out.
chrispi avatar image
chrispi answered ·
Hi all,
In process to integrate the SBMS into VenusOS/cerbo. It will be done via dbus-serialbattery from Louis and Manual (who is supporting it) via MQTT and Node Red. It was already succesfully done by a user on github who provided me his Jason file. Difference is he is using an MQTT broker on his router while i need to use the venus OS MQTT broker and that seems to be the issue.
All setting adaptions on cerbo/Venus OS are done and SBMS are done:
1) on Venus OS updated all to latest release and installed Venus OS large
2) enabled node-Red, MQTT and superuser access
3) Venus OS has an integrated MQTT broker, ip of cerbo and port is 1883 for plaintext and 8883 for SSL.
4) enable MQTT client on SBMS connecting it to MQTT broker with iP of cerbo (in my case 192-168.8.138) with port 1883
5) installed dbus-serialbattery via SSH and Root access on cerbo
6) I have Node-Red jason file that runs correctly on another installation (and Electrodacus shows up on cerbo as JK BMS) but with the MQTT broker on its teutonik router while I use the internal MQTT broker of the venus OS. So I changed the IP-Adress from the teutonik router to the Ip adress of my cerbo, which is 192-168.8.138 with port 1883 and deployed it on node red.
But the BMS doesn't show up on the device list in cerbo, so whats the problem here?
I checked the dbus-serial is correctly installed, i get the config file and also modified that to 400A charge and 500A discharge.
I check with MQTT explorer that 192-168.8.138 with port 1883 is the MQTT broker of Venus OS, i get the output of the broker.
I assume I have a problem connecting the SBMS MQTT service (in jason) to the MQTT broker but how do i check?
if i deploy the jason file the SBMS input node shows connected but I don't get the values from the debug nodes.
What does that mean? is the SBMS output jason stream connected correctly to the victron MQTT broker?
the jason file i use can be find here: https://github.com/Louisvdw/dbus-serialbattery/discussions/556#discussioncomment-7983132
